wiring a mini me setup for vtech
wat do i have to do wat wires do i have to run to make the v tech run lmk wat wires do i connect to the comp
Re: wiring a mini me setup for vtech
Here's the link in case you have a different model.
http://www.vtechphones.com/vtechui/s...m?manualID=107
1. Choose an area near an electrical
outlet and a telephone wall jack.
2. Plug the AC power adapter into an
electrical outlet and the DC connector
to the back of the Base Unit.
NOTE: Connect power to the
Base Unit before placing the
Handset in the cradle.
3. Set the TONE/PULSE switch located
on the underside of the Base Unit. If
you have touch tone service on your
phone line, set the switch to TONE.
If you have rotary service, set the
switch to PULSE.
4. Set the RINGER switches to HIGH,
LOW or OFF on the Base Unit.
5. CHARGE THE HANDSET BATTERIES
BEFORE USE. The batteries
recharge automatically whenever
the Handset is in the Base Unit
cradle. The batteries must be
charged for 16 hours before using
your phone for the first time.
6. Connect the telephone line cord(s).
If you have two lines which are serviced
by one telephone jack (RJ14),
insert one end of the four wire (black
tipped) telephone line cord into the
jack marked L1/L2 at the rear of the
Base Unit. Plug the other end into a
telephone wall jack. If your two telephone
lines are each serviced by a
separate telephone jack (RJ11),
insert one end of a telephone line
cord into the jack marked L1/L2 (this
will be your line 1) and a second
telephone cord into the jack marked
L2 (this will be your Line2) at the
rear of the Base Unit. Plug the other
end of the telephone cords into the
appropriate wall jacks. Make sure
the plugs snap securely into place.
7. CHECK FOR A DIAL TONE. After
the batteries are charged, pick up
the Handset and press a LINE key.
The LINE key you pressed should
light up, and you should hear a dial
tone. If not, see IN CASE OF DIFFICULTY
I was really trying to think of some creative way to explain that it is vtec and not vtech, but it looks like you got me beat...Props man...
Let me help you out, this information is taken directly from vtech web site.
switch to PULSE.
switch to PULSE.
Real Creative, The both of you. This is why HT sucks ***. Atleast help him out instead of being a douche, Good job on cloudin the forums with trash.
OP. Im not sure of your Generation. But.
Heres 92-95 OBDI wiring.
http://www.superhonda.com/photopost/...ring_92-95.jpg
Heres OBDII 96-98 wiring.
And heres 99-00 OBDIIb
http://www.phearable.net/tech/wiring/wiring.99-01_2.jpg
Its really easy to do, Ignore the asshats above.
vtec solenoid is the green/yellow wire on the left. Oil pressure switch is the black and blue wires with the thumb on them.
vtec solenoid wire goes to a4. oil pressure switch goes to d6 and other wire is a chassis ground. (All this is assuming you're using a P28 for a mini-me swap)
good comment vs bad comment
Try look at the sticky before you make a thread please.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/
Wiring Up VTEC On '92-'95 Swaps With a p28 ECU (Z6, ZC, Z1, or Mini-Me Swaps)
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-how-wiring-vtec-into-eg-non-si-civic-thats-not-92-obd1-w-p28-724252/
VI Boost
12-18-2008 01:54 PM
