Wheel bearing quetions. 94 Civic CX
Old 12-18-2008, 10:52 AM
lv6l's Avatar
Default Wheel bearing quetions. 94 Civic CX
I think my wheel bearing is going bad. When the front of the car is lifted up, I can grab the wheel and tires and slightly shake it and hear the thumbing noise. This is only on the passenger side. My question is, if I pressed out the bearing do I need to replace it with a new bearing or do I just press it out and repress it back on or what should I do? Thanks.
Old 12-18-2008, 11:31 AM
Jas9848's Avatar
if its the bearing, the wheel and tire will have play in all directions. if its a tie rod it will have play side to side. if its a ball joint it will have play up and down. i would replace any part that has play.
Old 12-18-2008, 01:28 PM
BlueIntegraBoy's Avatar
If you press out the wheel bearing, press in a new wheel bearing.
Old 12-18-2008, 01:57 PM
lv6l's Avatar
I see. Will check and get back to you guys. Thanks.
Richard N
Honda Civic (2001 - 2005)
03-11-2018 07:33 PM
Mad-Mike
06-08-2013 06:55 PM
audiobyalbert
10
06-25-2010 07:14 AM
thunderboy
03-20-2009 12:15 PM
Quick Reply: Wheel bearing quetions. 94 Civic CX
