clutch is loose
ok on the transmission is the slave cylinder and on the slave cylinder is a bleeder valve, you will need a bottle filled half way with new brake fuid and a hose that fits the bleeder valve.. and then you have a buddy in your car pump the pedal three times and then open the valve and then close then repeat process til tight
Bleeding a clutch takes all of 5 minutes. If you took it to a garage they'd probably charge you 30 minutes of labor..you can do it yourself. Just follow the instructions listed above, I did this today in about 3 minutes.
to actually replace a clutch shops do charge about 300-400 dollars in just labor so start by bleeding the clutch hydralic system and then see where it goes from there
as said, check for leaks fromt he clutch master cylinder to the slave cylinder, drain and renew the fuild if there are no leaks, if there are leaks, id be pretty sure it will be the slave cylinder thats at fault, peal back its rubber cover and see if the fluid has gone past the seal, if so, replace
al9955
al9955
na but u have to put the bleed valve back on immediately after some air and brake fluid squirts out.it could be ur slave or master cylinder though if u bled it right
well when you bleed the clutch you pump the pedal three times and hold it and have someone open the valve then close it but if that didnt work change your master and slave cylinder
