really bad shakeing need help quick
ok i just put a b18b1 in my 95' dx hatch everything works fine but when i drive and turn to the right it shakes really bad like a tire that has loose lugs. but when i turn left its fine and normal i looked to see if anything was grabbing and everything is fine as far as i can see. when we were pulling the axles the driver side one came out of its socket exposing the bearings but we put it back together it has the square bearing things and they only went in one direction so i think we put it back together right.. any ideas of what could be wrong?
Re: really bad shakeing need help quick
BuMp ... really need some help any ideas or anything. if the axle bearings are backwards could that cause it?
is the suspension stock?
check the axle, halfshaft, bearing in the spindle.
was it doing this from the getgo, or did it just start out of the blue
i just started right after the swap was done. i had a d15 in it before this b18 and it never done this. the suspension isnt stock i have nuspeed race suspension but it came with the car when i got it.
Does it make a clanking noise while turning? I would double check each bolt/nut for suspension since you did the swap.
If everything is tight, I would have to go with axle for sure.
tooslohatch
05-15-2012 09:04 AM
1337 Si
04-04-2005 08:39 AM
Ivan
28
07-01-2003 07:49 PM
