b20b in a ek wont idle
i have a 99 ex and just put in a b20 w/b16 trans using the stock harness and a obd2b to obd1 harness. im using an ls ecu.
car cranks over and starts, but will not idle. it runs like **** if it runs but you have to hold the throttle about a quarter open. fuel pressure is like 44psi, stock injectors, its an 96 ls distributer with a adapter to the ex engine harness. i have spark and fuel.
i pulled the plugs and it looks like cyl 1 and 4 are lean as hell where as 3 and 4 are black.
think this could be bad injectors? maybe a bad ecu? im out of ideas and need some help
yeah i had a very similar problem with my 97 civic ex. Be sure you check your fuel pump pressure again and also you might want to check oil pressure and levels and alll that and finally you could check the IAC valve, if its all dirty and **** just spray it with carb cleaner really well and put it back on.
also maybe your timing is off too
Re: b20b in a ek wont idle
doodooheadfart
22
10-29-2007 12:01 PM
vtec4max
07-13-2007 10:25 PM
97ShLude
12-10-2006 09:47 AM
Capt. Jimbo McSubipants
04-25-2005 04:14 AM
