vibration in civic after new axle install
H22a 93 civic ~ H22 intermediate shaft ~ 90 integra axle ~ H22a inner
I have just replaced my pass axle and took it for a drive.
But now have a vibration..feels like a small patch of mud on the wheel..
consistent small bump bump..as speed increases it gets worse.
and when I swerve left 20+ mph bumps get worse.
axle nut tightened to spec
lug nut tightened
axle is locked into tranny
no play in the axle
So What then?
lug nut tightened
no play in the axle
So What then?
So I put the old teg axle in with the h22 inner and it drives smooth!
but put the new teg axle with h22 inner in after and drove ..... bump bumpedy thumpedy~
I took 1 teg axle back to autozone allready!! Should I take this one back also!! aaaa
I would they dow have diff levels of axles. Makke sure you get one that has a new outer joint on it
I gave up. Without feedback abou the axle setup I decided to buy the hasport axle 192.00 shipped for passenger axle. O well I believe this problem is over with. Thanks for the feedback I did get.
jobber axles have that problem sometimes (reman axles)
we used to send some back when i worked at Acura even though it's a "new" axle.
hope the hasport ones solve your problem
Re: vibration in civic after new axle install
It seem the axle just doesnt work for my h22 93 civic setup. The hasport axle will be here this week and I'll post the good news hopefully.
Not to revive an older thread, but I just ran into the same type of deal.
I work at Advance Auto parts these days, and I am on my 3rd axle which finally seems to match up. That's right, same part number on every box, each axle just a little bit different to where it won't work.
Maybe, when considering new axles, just to Raxles or Hasport and be done with it. Messing with parts houses is getting old.
raxles is the place to go mann... i have heard nothing but good things from there.... they also do custom set ups if they dont already have your application available
