The difference between Short ram and Cold air
What is the difference between short ram and cold air intake?
Which is better?
Which do you perfer?
What brand do you perfer?
Im running this on a d16z6 bone stock.
i was thinking of Red Aem cold air intake with K&N filter.
This is probably a dumb question but im a noob still trying to figure out how to work this. Any advice would be awesome.
Thanks
delsoldude30
-Frank-
Which is better?
Thanks
delsoldude30
-Frank-
Re: The difference between Short ram and Cold air
short ram is going to stay in the engine bay, where as cold air is going to drop down into the fender well/behind the bumper area. dont waste your money on something fancy from aem, its not necessary. it's just a pipe and a filter. there are times to purchase name brand things, but this isn't one of them.
I agree with the previous posts, to add to that it is dangerous to get a cold air intake, because of its location, during a decent rain it is very easy for water to splash into the intake and hydrolock your engine.
I have one I did custom I didnt want it low to the ground to suck water when hitting puddles and I didnt want it close to the block. My car dosnt have ac anymore so I make a tube that runs were the old ac fan and stuff was so it sucks air from the front bumper vents.
H-T White Ops
Which is better?
Thanks
delsoldude30
-Frank-
Which is better?
Thanks
delsoldude30
-Frank-
The CAI runs the risk of you sucking water up, but you'd have to submerge the tube. Hydrolock isn't inevitable just because you have a CAI and it rains where you live.
The SRI loses low end power. It was enough to be bothersome and noticeable on my D16Y8.
I went with AEM on both because though some say it's just a tube, those brackets keep it from knocking around in your engine bay, damaging other parts or the paint finish in the bay.
In the end though, they're both worthless unless you really need that extra room on the passenger side. I felt it made the engine bay look empty anyway.
I only put the SRI on my car after the CAI was stolen. I wanted to replace it before with a stock airbox, but had trouble finding one even after the CAI was stolen.
You don't need a photo.
A stock airbox and drop in filter are what you currently have.
A drop in filter by K&N is a reusable air filter that you can clean. When the car is assembled it looks exactly the same as it does now (if you have a stock airbox).
Go to Autozone or anothe auto parts store and ask them to look up your vehicle's air filter. They should sell K&N air filters too. If you were to look at it, it's square and shaped to fit into your car as is.
As far as the resonator in the bumper, my understanding is not all cars have that. But yes, remove the entire bumper before you remove the resonator. When you remove the bumper you will be able to see the plastic resonator connecting to the air box. It's usually black or sort of clear.
Almost forgottoo lol... A stock airbox doesn't make your car sound like a freakin hoover when you get on it
I run an icebox and stock itr intake tube on my racecar... it made a noticeable difference when I switched from an aem cold air.
H-T White Ops
Actually, my current stock airbox without a resonator in the bumper sounds the same as the AEM CAI I used to have.
I had a del sol si with a D16Z6 in it.... had a SHORT ram air intake.....Bought a Cheap Ebay COLD air intake... for like $75 It gave it a deeper sound and I "felt" more top end.. I was happy with it.. as for the hydro-lock... you can pay an extra bit of money for a Bypass Valve witch will stop water from getting to your motor... problem solved.. and you get more gains with a cold air... I personally opted not to get the bypass valve because it take a big GULP up water suck enough up to hydro lock.. so I just avoided hudge puddles and I was good even through down pours...... If you want the stock look do a drop in K&N air box filter.... If you want I diferent look do a Cold air. worth it
H-T White Ops
A CAI *or* removal of the intake resonator in the bumper (if equipped) will make the car sound deeper when you get on the throttle.
H-T White Ops
I think intakes look stupid. They leave a giant hole in your bay. A CAI filter is also (1) not easy to change and (2) not usually visible, so it might be easy to forget to even look to see if it's dirty.
A stock airbox filter is easy to change. A couple clips and the cover is off. Then you just lift the filter out.
Aftermarket cone style filters are a pain to change. I know because I have customers come in all day long for this. You need to know the measurements of the filter you want. Few people seem to understand we can't just look it up on the computer. More than likely we will also not have it in stock (the Spectra filters don't usually work or get returned for some other reason). So you will have to wait 1-7 days for a filter.
Stock size filters are almost always in stock. If they're not, the store can often store transfer the item from another store to theirs by that day or the next afternoon. Or you can drive to the nearest store with one (your store can call around for you to be sure).
Not to mention the stock air box won't wobble around in the engine bay like I mentioned before.
Also, if the OP decides later that he would prefer to have the stock intake again, all he'll need to do is replace that resonator (which is not too large to store in the garage). It took me forever to find a replacement and I still don't have a resonator because many people leave them on the car when they put a SRI on.
I use a cheap aluminum ebay short ram tube and a cheap filter. Although i would recommend using the same cheap tube but using a better filter. Do as i say, not as i do :p
Vietnamese!
A K&N filter shouldn't require any wait to get your product plus it's reusable.
