VTEC issue
Old 07-07-2009, 11:13 AM
JDMtegg19's Avatar
Default VTEC issue
in a 99 civic si.. i was driving it and out of no where vtec started acting up.. it would just cut in and out between 5500 and redline. finaly the CEL came on and the codes are as followed:
P1259: VTEC System Malfunction
P1298: Electric Load Detector (ELD) Circuit High Voltage (ithink 1298 was the code)
has any one ever ran into this problem before?
Old 07-07-2009, 11:27 AM
iamthefollower's Avatar
Default Re: VTEC issue
did you check the oil level??
Old 07-07-2009, 11:34 AM
JDMtegg19's Avatar
oil level was very low
Old 07-07-2009, 11:42 AM
that's the reason for the cutting in and out and the CEL for the vtec.. now we gotta figure out why the other CEL was on... anyone got an idea on this one??
Old 07-07-2009, 12:35 PM
supra-n-civic's Avatar
reset the ecu change/fill the oil and go for a drive then check codes they are probly interrelated.
Old 07-07-2009, 12:39 PM
roadsqueegy95's Avatar
ya vtec prob was because of low oil. now sure about codes. first one probly was caused because of the low oil? id do what supra-n-civic said to do
Old 07-07-2009, 01:52 PM
JDMtegg19's Avatar
thanks guys i appreciate it im gonna check that out tonight after work and give the results tomorrow morning
Old 07-10-2009, 07:43 AM
JDMtegg19's Avatar
well the problem is solved filled up with oil and runs mint again thanks for the help guys
Old 07-10-2009, 07:45 AM
sp00ledbseries's Avatar
It aint mint again. Why was there no oil in the first place
Old 07-10-2009, 09:58 AM
true, do you have a leak somewhere or is it blowing it out the exhaust?
Old 07-10-2009, 10:08 AM
JENNY_EG6's Avatar
you could be burning oil!!! ^^
3JP
06-07-2010 10:36 PM
high_octane
06-16-2009 01:55 PM
shoklid
05-07-2009 04:20 AM
DohctorVtec
01-16-2007 05:43 AM
MontrealR
09-15-2001 07:51 PM
Quick Reply: VTEC issue
