Will the codes make it so VTEC wont engage?
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
If so how do and where is the cylinder sensor plug? and where di I get one. This is all for my obd 1 gsr block with b16 head motor and my vtec dont engage? and its all wired up correctly I think can I get a diagram I tryed searching but cant find the correct one.
Re: Will the codes make it so VTEC wont engage?
I'm at work right now so I don't have access to the troubleshooting flow charts.
Fix these CELs and you should be good. Did these come up right after doing the swap or was the motor running fine for a while and they just came up?
Cool Cool Island Breezes. BOY-EE
What ECU? Who did the wiring? Did they know what they were doing? Why do you have those codes?
What type of car is this in? This would be an important peice of info. Make sure you include the year in your response. Wiring diagrams depend on the year of the chassis, usually.
CYP code usually results in a 3k rev limiter or a non running car all together. It's in the distributor.
The IAT is a very important sensor...but VTEC will operate without it, IIRC.
Its a 1995 Honda Civic CX
P72 Ecu
A Buddy did the wiring and vtec worked before I did the b16 head swap.
And no my car still goes all the way up in the revs.
P72 Ecu
When you did the head swap did you use the dizzy that was on the car before? The CYP code is the reason your VTEC isn't working, limp mode sucks. The IAT issue is important to fix as well but as stated it wont prevent VTEC from working.
I will see what I can do to get you the troubleshooting flow charts for your build once I get off work. You have a multimeter and know how to use it well?
There ya go, bust out the multimeter and run through the flow charts. Fix these two CELs and you will have your VTEC back..
So running through the flowchart the results point to a bad CYP sensor huh?
What were the results of the tests of the IAT system?
zx2gotboost
04-22-2011 01:42 PM
