Hondata Intake Mani gasket!?!
Old 07-07-2009, 08:00 AM
EX-T's Avatar
Default Hondata Intake Mani gasket!?!
I just installed a Hondata intake manifold gasket on my Y8 and was wondering if there was any kind of liquid gasket I was supposed to use b/c it's leaking. I'm thinking that it's possible that the underneath bolt isn't as tight as it needs to be but I'm still wondering if I was supposed to put some kind of liquid gasket on it as well...
Old 07-07-2009, 08:01 AM
Pothole987's Avatar
Default Re: Hondata Intake Mani gasket!?!
Usually you don't have too. did you clean both the head and IM?
Old 07-07-2009, 08:05 AM
EX-T's Avatar
Yep. The underneath bolt is really hard to get too, especially laying down. I have all the other bolts really tight, it's just that one I can't get to.
This weekend I'm going to put it on a lift and buy a stubby ratchet and several 1/4" drive extensions of different lenghts and I already have the U joint attachment for the sockets...
Old 07-07-2009, 08:13 AM
Sean Juan's Avatar
You don't need to use anything on it. Was it brand new? It might have been a little warped if not. Also are you sure it's a real one? People sell knockoffs believe it or not that will melt slightly.
What makes you think it's leaking?
Old 07-07-2009, 09:06 AM
EX-T's Avatar
yes, brand new - hondata, not a knockoff. It's leaking b/c it idles at 2k and when i spray brake cleaner between the IM and head, it bogs the engine...
Old 07-07-2009, 09:15 AM
I'm not Rick!
rick_rabies's Avatar
those gaskets are JUNK. $40 for junk. no offense. i had one to and it leaked. so i set it on fire
Old 07-07-2009, 09:25 AM
Matt93eg's Avatar
Originally Posted by rick_rabies
those gaskets are A. $40 for junk. no offense. i had one to and it leaked. so i set it on fire
LMAO!!! That made me laugh..funny stuff. Thanks for the laugh Rick.
Old 07-07-2009, 11:09 AM
Bull_head360's Avatar
those gaskets are useless imho, just use OEM...hell, when I swapped my IM for a skunk2 piece I used the old gasket, no probs What do those gaskets claim? more horsepower im sure...
Old 07-07-2009, 11:10 AM
zccivicex's Avatar
they are not junk if you know what your doing....after you drive the car you should go back and retighten it.
Old 07-07-2009, 11:23 AM
slvrlude's Avatar
yea, i have one with no issues...and they arent junk if you are using it in combimation with other power-adders
Old 07-07-2009, 11:53 AM
I'm not Rick!
i used mine with a turbo set up and a skunk2 intake mani. and i did retighten it. the stud barely made it all the way through. they are supposed to be reusable and lower intake temp by 4 degrees wich was like 1hp to the crank on the dyno that hondata did it made me want to get one...now its crispy
Old 07-07-2009, 12:27 PM
EX-T's Avatar
I'm going by autozone tonight and buying 2 stock intake manifold gaskets to put on either side of it! Guarantee it solves the problem and I'll be drivin' my car tomorrow!!!
w00t!
Old 07-07-2009, 12:39 PM
90Rexx's Avatar
hey kids why dont you read hondatas website.... they CLEARLY STATE the hondata heat shield intake manifold gasket requires extended studs for proper operation!
kthxbye
Old 07-07-2009, 12:42 PM
riceburner700's Avatar
we have never had a single problem with any of our hondata gaskets. and yes we recommend our longer stud kit on the intake side to get full amount of tention on the manifold to seal everything up nice and tight
Old 07-07-2009, 12:45 PM
90Rexx's Avatar
there ya go lol
Old 07-07-2009, 12:52 PM
I'm not Rick!
it fit fine. it just sucked
Old 07-07-2009, 01:57 PM
EX-T's Avatar
Ha, isn't the intake manifold supposed to suck?!?! =P
Old 07-07-2009, 06:24 PM
what a waste, 1crank hp?! You could gain that by letting out a fart, or taking the caps off your valve stems, Le$$ roTaTing MA$$ y0! gimme a break
Old 07-07-2009, 06:38 PM
Matt93eg's Avatar
LMAO!!!! This thread has been halarious. Between you and Rick..LOL!!
Old 07-08-2009, 06:51 AM
Sean Juan's Avatar
You don't need the extended studs. The nuts thread on just fine without them. Just torque it down to spec and retighten it after you drive it. The heat probably allows it to seal a little better since it will soften the plastic.
Old 07-08-2009, 07:11 AM
Marauder's Avatar
Do you have a 99-00 or 96-98?
The 99-00 D16Y8's have air-injection on them and I don't think that the Hondata gasket supports that.
Old 08-31-2009, 10:17 PM
ketchup's Avatar
w00t!
Well? Did that take care of your problem?
Old 08-31-2009, 10:55 PM
SWISS_MISS's Avatar
may be a dumb question but did you use the proper tightening sequence? i have put a few of these on and never had a problem. also a retorque is a must since it is plastic sandwiched in between two hunks of hot metal.
good luck
Old 09-01-2009, 05:17 AM
EX-T's Avatar
Nope it didn't work... I ended up taking it to a shop cuz I still couldn't get the middle bolt tight but even after that it still leaked. Not sure what was wrong with it. I have since totalled the car. =(
Kr4nG
04-04-2008 12:06 AM
kornerk12
04-26-2007 06:31 PM
GSR4U2NV
11
05-22-2005 08:04 PM
Houston Hatchback
20
02-18-2004 08:57 PM
nickwilmot
10-17-2003 01:58 PM
Quick Reply: Hondata Intake Mani gasket!?!
