changed the tranny now fuel pump wont start?
i changed the clutch in my d16z6, but when i was dropping the tranny i broke the wire that read for the speedo, it a 3 pronged gray clip.i drove the car with the clip brokedn and just had no speedo, then i trided to just put the wires back on using small femal butt clips and then it just cranked and got no fuel. the fuel pump is not primming, has a code but does not flash when jumped with the wire across the brown and green/white wire, totally lost i sure someon knows this... thanks
Re: changed the tranny now fuel pump wont start?
go to your fuel pump main relay... look for the yellow/green wire yellow being the main color and green is the strip color... cut it and strip the coat off abit then connect it with a connect to you optional underdash fuse box power source... if it still doesnt work then get under your car and check to make sure you connected all your wiring correctly take off the ground from the battery wait 2 mins then plug it back on before you do the fuse box thing i covered in this posting
i also checked the thermostat ground.. and got nothing.
put a ground from your transmission to the car body... something went wrong when you did the wiring again... disconnected everything and then reconnect
would that cause the drop in voltage to my fuel pump, because it ran unitil i tried to re hook up the speedo plug
maybe not really sure but what i suggest if take off all the wiring, clean up the plug and then reconnect. put a ground from the transmission to the engine bay. disconnect the battery then reconnect. you must have a weak ground!!!
i will do all that tomm, i ahve been working on this sense like 9 this morning.... i will post up with updates as soon as i do them..
SuicideSlide
02-17-2005 03:09 PM
hatchback_al
10-26-2004 10:00 AM
