Does anyone have the fuse box wireing diagram for the del sol?
I relocated my fuse box, and everything is working perfectly, only issue is I have an extra wire left over somehow. It's a thick blue wire, no idea where it goes. The only thing that's not working perfectly is my windshield wipers, but that's not in this fuse box is it?
H-T White Ops
Re: Does anyone have the fuse box wireing diagram for the del sol?
Look in the FAQ. There's a fuse diagram thread by me.
IIRC (without looking at my own thread), it's the same as a 5G Civic.
I found this, but it doesn't really have an answer for me: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/civic-del-sol-fuse-panel-printable-copies-fuse-diagrams-here-1966666/
The wire I am trying to figure out looks to be an 8 or 10 gauge blue with a white stripe.
let me see if alldata has it. i'm sure it does. i'll look up the wireing for the 93 del sol si....which fuse box did you relocate? so i can look at the right one
i found a blue wire with a white stripe on the connector 509 in the number 9 **** of the connector/harness...but the under dash connector is connector 501....is this the fuse box? under the dash? on the left side
so under the dash i see blue wires with white stripe for fuse 3 and fuse 18. both are 7.5 amp fuses. then the back up fuse under in the under hood relay box fuse 32 also 7.5 amps...goes to the under dash relay fuse box to connector 431 in the #13 spot.
there are also blue wires with white stripes on the wiper motor circuit. one goes from the RUN location on the windshield wiper motor to connector 306 to connector 302 and to connector 436 to the PARK INPUT on the integrated wiper control unit.
I relocated the underhood fuse box to under the dash, it is on either the 205 or the 202 harness.
damn!! LOL i can tell you that its not C202. thats a 3 wire connector with the wires being 1-WHT/RED, 2-WHT, 3-WHT/BLK. the C205 is a 7-wire connector, brown in color and is part of the main wire harness. i have to go through each wire circuit in the electrical schematics to find your BLU/WHT wire in the connector. i found the BLK/YEL wire so far. its for the blower motor and radiator fan relays (C904 and C905). give me till later today and i'll go through the rest. maybe this will help you eliminate the possibilities and put it in the empty space on the C205 connector
okay i found the BLK/YEL wireon C205 the BLU/WHT wire to connector C402 and to C723 to blower motor possibly this goes in terminal 6 on the C205 connector. i also found the BLK (ground) in the #2 terminal of C205 possibly. goes to G201. theres also a note about rear window defogger relay on this wire....but this isnt the wire you asked about...i just went through every page in the wiring schematics looking for C205.
does any of this help?
Matt Richardson
06-08-2018 09:49 AM
