metal against metal schreeching sound
today my friend installed my hawk ceramic pads and brembo blank rotors on my 2000 civic EX. after the install ive noticed a screeching sound when i take right turns or when going over bumps. is there anything that could have been done such as over tightening that could cause this sound....
also i had my inner and outter tie rod boots replaced about a month ago due to them being torn. i noticed tonight one is leaking but just a little bit. could that have anything to do with it?
Re: metal against metal schreeching sound
rattle clips likely... or, did you put a pad on backwards?
also, did you machine your rotors, or put new on? if you're using the same old unmachined rotors, you are likely burning off the rusty lips on the edges of the rotors, causing the noise...
its not really a rattling noise....imagine your rotor being turned and you taking something metal and rubbing it against it....thats the best way i can describe it.....hopefully ill figure it out later tonight
thats something else i have also considered......but like i said earlier it doesnt do it when turning left. its coming from the front drivers side wheel....could that still be possible?
yes i did this right after i installed them
yea 6-10 35-0's and like 4 45-0's....
i figured out the problem.....it turned out that the dust shield was rubbing the rotors on the bottom....just bent it out a little bit and were all clear now. thanks to everyone who gave suggestions!
2000EJ8
Suspension & Brakes
04-23-2010 01:02 PM
onephatcivic
17
06-13-2004 01:17 PM
nd8ch
17
08-21-2003 11:24 AM
