B18b swapinto 92 Cx Hatchback
Re: B18b swapinto 92 Cx Hatchback
use the search engine or just go to the faq section, it'll give you all the info you need. but you will prolly need a harness for the motor. it should plug n play into ur car.
the harness should still work, but if its the 96 and up b18b, you'll need an ecu conversion harness, check out rywire.com, they're under 100 bucks. try to find out what ecu your running with the new motor
Psychoteen101
14
06-29-2009 11:02 PM
