Swapped LS into eg problem ( help )
Ok i just got done swapping a 96 b18b1 out of an integra into my 1992 civic cx. It is running off of a po6.
It will start but barely run and sputter, after i rev it past 3k it clears up. same as in gear, is it because its running too lean from the po6?
im new to this, please help
Re: Swapped LS into eg problem ( help )
the cx has an economy tune for a high mpg rating. you can swap for a dx ecu, but an odb1 p75 would be optimal. all odb1 ecus have the same plug in. if you want odb0 you will need a jumper harness.
alright ill have to see if i can find another obd1 ecu..
i think the ecu off the teg is a p75 but obd2, ill check and write back
99ej6gsr
06-11-2009 10:22 PM
