Starter/Cranking Problem? Fidanza Flywheel on a 91 Civic RT4WD.
I bought a used Fidanza flywheel that came off from a 92-95 civic. From what I told it would work on any 90+ Civic. Cable or Hydro. I also relocated my battery in the rear this time with a 4 gauge wire. Tried starting it & jumping it but all I can get is a "TACK TACK TACK" from the starter... as if the teeths aren't aligned up correctly to turn over & crank. Any thoughts?
Re: Starter/Cranking Problem? Fidanza Flywheel on a 91 Civic RT4WD.
Maybe you didn't properly install either the fly wheel or the starter when you put the flywheel in.
