rear sway bar????
Re: rear sway bar????
Integra lca's, all the corecct mounting brackets for the sway bar, and integra endlinks.
Im pretty sure you need the integra lcas unless the stock ones have holes in them for endlink
yes, you can use any aftermarket lower control arm made for a dc or eg, but those are the only 2 with the holes in the correct spot, to use the others you will need to use aftermarket adjustable endlinks.
Jimmy
Suspension & Brakes
11-26-2010 03:09 AM
spock_rocker
05-23-2004 06:43 AM
