please help me with radiator hoses
I need to replace all hoses on my 1994 civic SI with a JDM 1993 B16A engine, (all 10) the part numbers are tricky, i looked up the parts for both the 1994 civic SI and the 1994 Del Sol VTEC, and the first 5 numbers (XXXXX-XXX-XXX) of each part from honda are the same matching numbers for both the civic and delsol, but the next 3 numbers/letters are different, and so are the following 3 numbers/letters.
Are these parts the same on both cars, since the first 5 numbers in the OEM honda part numbers are the same?
The reason im asking is the price for the civic SI part numbers are much cheaper than the parts listed for the delsol VTEC
19501-P08-000
HOSE, WATER (UPPER) CAN 1 $12.93 $9.11 *
10 19502-P08-000
HOSE, WATER (LOWER) CAN 1 $27.12 $19.66 *
3 79721-SR3-000
HOSE A, WATER INLET CAN 1 $18.65 $13.52 *
4 79722-SR3-000
HOSE A, WATER INLET CAN 1 $5.55 $4.02 *
5 79725-SR3-000
HOSE, WATER OUTLET CAN 1 $13.13 $9.52 *
1 19506-P08-000
HOSE, ELECTRONIC AIR CONTROL VALVE INLET CAN 1 $2.38 $1.73 *
2 19507-P07-A50
HOSE, ELECTRONIC AIR CONTROL VALVE OUTLET CAN 1 $8.47 $6.14 *
3 19508-P08-000
HOSE, BYPASS OUTLET CAN 1 $9.03 $6.55
5 19527-P08-000
HOSE A, BREATHER HEATER CAN 1 $4.63 $3.36 *
6 19528-P07-A50
HOSE B, BREATHER HEATER CAN 1 $5.45 $3.95 *
DOHC Vtec
1 19506-P75-000
HOSE, ELECTRONIC AIR CONTROL VALVE INLET JPN 1 $5.42 $3.93 *
2 19507-PR3-000
HOSE, ELECTRONIC AIR CONTROL VALVE OUTLET JPN 1 $8.03 $5.82 *
3 19508-P08-000
HOSE, BYPASS OUTLET JPN 1 $9.03 $6.55 *
5 19527-P30-J00
HOSE A, BREATHER HEATER JPN 1 $6.95 $5.04 *
7 19528-P30-J00
HOSE B, BREATHER HEATER JPN 1 $6.95 $5.04 *
9 19501-P30-000
HOSE, WATER (UPPER) JPN 1 $23.28 $16.41 *
10 19502-P30-000
HOSE, WATER (LOWER) JPN 1 $31.08 $22.53 *
4 79721-SR3-J30
HOSE A, WATER INLET JPN 1 $20.58 $14.92 *
5 79722-SR3-000
HOSE A, WATER INLET JPN 1 $5.55 $4.02 *
6 79725-SR3-J30
HOSE, WATER OUTLET JPN 1 $13.47 $9.76 *
19501-P08-000
10 19502-P08-000
3 79721-SR3-000
4 79722-SR3-000
5 79725-SR3-000
1 19506-P08-000
2 19507-P07-A50
3 19508-P08-000
5 19527-P08-000
6 19528-P07-A50
DOHC Vtec
1 19506-P75-000
2 19507-PR3-000
3 19508-P08-000
5 19527-P30-J00
7 19528-P30-J00
9 19501-P30-000
10 19502-P30-000
4 79721-SR3-J30
5 79722-SR3-000
6 79725-SR3-J30
93 del sol si2
07-12-2013 04:21 AM
Ohmster
04-21-2008 05:13 PM
screen_name
04-30-2005 05:54 PM
