D15B7 wont rev past 3k rpms!! im stumped!
OK i have a 93 civic lx d15b7 5 spd. i can start the car up fine. it will idle fine and get to normal running temp.
Problem.. When i rev the engine up it hits 3k rpms sometimes 3.5k and then bounces down to 0 and stalls out the car.
i have heard backfires maybe 2 or 3.
what has been replaced:
vacuum lines
rotor and cap
ignition module
ignition coil Please Help!! thanks in advance
fuel pump for viewing.
fuel filter
spark plugs
wires
throttle body gasket
exhaust manifold gasket
vacuum lines
rotor and cap
ignition module
fuel filter
spark plugs
wires
Re: D15B7 wont rev past 3k rpms!! im stumped!
vacuum lines
rotor and cap
ignition module
fuel filter
spark plugs
wires
vacuum lines
rotor and cap
ignition module
fuel filter
spark plugs
wires
hey i have no cels. i just wanted to talk with you seeing as how you seem to be on most. in reference to the d15b7 post about rpms not going past 3k and the car stalling
have you tryed the tp sensor and the map sensor wires they are right in the intake mani they have the same plug and may be hooked up backwards happend to me before
CaptRexKramer
11-10-2014 01:13 PM
sethmoman
02-07-2012 10:13 AM
sethmoman
01-11-2012 05:54 AM
Eman48
11-09-2010 04:59 PM
