94 Civic CX/d15b7/p06 ecu - cel code 7
So my car just got a cel code 7. I got a new tps and the problem still persists. The car was bogging so I unplugged the tps and it still bogged. Is the problem my ecu? Thanks.
Re: cel code 7
Re: cel code 7
Reconnect the TPS plug and turn key to ON(II) [engine not running]. Backprobe the TPS Red/Blu wire (+) and the TPS Grn/Wht wire (-). What voltage do you read?
Re: 94 Civic CX/d15b7/p06 ecu - cel code 7
Ok Ron I have some things to do real quick and then I'm going to get right back at it. Thanks for all the help so far its much appreciated. I'll let you know when I go check the continuity.
Your test results point either to a bad TPS plug, bad TPS, or bad connection between the Red/Blu wire pin in the plug and corresponding contact point with the TPS.
Start here:
Unplug the TPS connector and turn the key off. Measure continuity/resistance between the Red/Blu wire pin in the front of the connector and some point in the Red/Blue wire behind the connector (pierce through wire insulation). Is there continuity?
Start here:
