2000 civic ex D16Y8 into a 1998 civic ex.
I'm sure there is somewhere that I can search and find the answer to this but I've been looking for a few minutes and can't find the answer to my question so I figured I'd make a post.
I have two honda civic Ex's. One is a 1998 and the other is a 2000. I know that the 96-98 are OBD2A and the 99-00 are OBD2B. I'm planning on pulling the motor from my 2000 civic and putting it into my 1998 because the 98 has a bad motor and the 2000 is going to be getting a B series swap in the next few weeks.
My question is this... Will I be able to just have a direct swap or are there actual different plugs on the motors them selves? I know that the ECU plug is different and I suspect that there are no other differences on the engine but I just wanted to be sure.
Thanks!
Thanks!
Re: 2000 civic ex D16Y8 into a 1998 civic ex.
looks like the dizzy plug is different
98:
2000:
o/p just re use the 98's dizzy/engine harness/ecu and you'll be all good
98:
2000:
O.G. triple O.G.
Instead of doing two swaps.....why not do the b-series swap into the '98 and keep the '00 the way it is??? Unless of course you have all the time in world.
Good info! Thanks!
I would pull the 00 engine and remove everything from the head and use the parts from the 98 blown engine such as the dizzy, intake manifold etc so its a direct swap plug and play.
Tre_savage900
08-02-2018 12:07 PM
