What's a good diagnostic tool for a 92 Civic?
Re: What's a good diagnostic tool for a 92 Civic?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
This ^^^
And get yourself a multi-meter
You can also look into - compression tester / Leak down tester
This ^^^
https://honda-tech.com/forums/showthread.php?t=1901557
This ^^^
This ^^^
Seagull Management
I should add that having a real scanner is nice, they will do a lot more than just give you codes, you can check freeze frame data, check things like O2 sensor response times and such that you just can't do with a paperclip.
A vaccum guage, compression tester, leak down tester, fuel pressure guage, vaccum pump, mulitmeter, smoke machine, BFH
As stated above...don't think their is anything like that. It's not hard at all to pull/count the blinks.
You know how to do that and have a multi-meter...it will do wonders!
The 16-pin tool is for obd2 cars and select 94/95 gm cars (they were early adopters of the connector but not the standard (those cars still spoke ALDL I believe)) Not sure if there is even any Snapon Brick support for early hondas, though supposedly there is a honda adapter but I dont guarentee that info. And if counting isnt your strong point, beer buys many friends who will count for you.
