b16a2 94 Hatch Broken Coolant Bleeder Valve
JDM b16a2 installed on a 94 Civic Hatch CX 60k
Someone has snapped the coolant bleeding valve from the "water outlet cover"?
Quick valid questions please:
Question 1: What is this part called for my b16a2? Where can I get it replaced? Is it easy to remove this assembly? I havent had a great look at it on the backside of the motor. Been dealing with 100 other things.
Question 2: I have the bleeding screw and the little housing it threads into. Can I glue , weld or attach this back onto the block? Looks to be the similar material as the engine. Cement block material stuff?
I temporarily have a screw lightly twisted into the hole.. Seems it holds the coolant under pressure.. I dont want to rely on it. I keep checking it every so often while driving.. Dont want to hit high RPMS much.
How do i permanently repair?
Any advice would be helpful.
Also looking to buy the "water outlet cover" for a b16a2, or whatever it is called.. Is this the correct term?
Thank you in advance.
Re: b16a2 94 Hatch Broken Coolant Bleeder Valve
Hey thanks a bunch. I really do appreciate it. I will try to share what knowledge I have as well.. Let me know if you need anything
steveeb
06-07-2013 07:14 AM
hundreds08
03-10-2013 09:42 PM
