Poly inserts = wicked vibration.
I purchsed the set of poly motor mount insert for the rear , left and right motor mounts. I read alot of theads about window weld and etc but these were cheap so I figured why bother.
Well the inserts arrived in the mail I was nervous right away since they were rock hard.
Well today I installed the passanger and rear inserts. And the vibration made my brain rattle. I ended up removing both passanger side inserts , and I removed one of the two rear inserts. But there is still a very noticeable amount of vibation.
This is no race rig, just a daily.
If anyone has window weld mounts or something similar. Please give me some details on the softness of the mount and if you have any vibration .
Re: Poly inserts = wicked vibration.
k , i've never felt in person. But the poly inserts are pretty much rock hard. A buddy of mine said GEO-GEL is a good filler that isnt rock hard.
do I have any other options?
Or should I try to remove the rear mount insert and leave just the side inserts ?
H-T White Ops
Stiffer/harder mounts will give you more vibration.
I have poly bushings in the rear of my Civic. Not comfortable, but they came with the rear trailing arms.
My CRX has stock trailing arm bushings and it drives great! I will never go with poly for a daily especially.
Simply no way you can get better performance AND a comfy ride in this respect. Poly bushings remain on the track.
Get new oem mounts.
Get new oem mounts.
The Grumpiest
Hardrace mounts. Hard rubber (75a). Stiffer than stock with far less vibration than poly mounts/inserts. Been running these for 5 years now.
onyx00
09-24-2004 01:00 PM
TypeRuz
02-07-2004 10:04 PM
