Engine swap, or buy another Civic?
I have a 1995 DX Civic, manual, with 145k miles. The engine needs to be swapped, because the crank will go out soon. But everything else is in great condition, though it’ll probably need a new clutch in 10k miles.
What would you do between these two options?
1) Pay $1200 for an engine swap to an identical engine with 45k miles. Maybe I could lower the cost more by parting out my engine, since everything but the crank is good.
2) Sell my car and get another mid-90s Civic with about 130k miles on it for a total of $700 out of pocket.
I’ve never had a serious car problem *except* for engine problems, so I don’t really know how to appraise the value of a car with 145k on the body and 45k on the engine.
Re: Engine swap, or buy another Civic?
id buy a new motor but thats juist me. u know it will be a fresh one and odds are paying that 1200 will give u a motor that most likely last alot longer then buying the car for 700 when in time who knows what will happen to it. u will prob end up spending the extra 5 bills in the same time the new motor will still be runnin fine. depending on how u drive.
If you def are going to get a civic again and yours is sound do the engine. A used car is a crap shoot, cooling system could be shot, electronics shot etc.
I think that for someone who has a lot of knowledge about the value of these cars, yes, it's a pure finance question. But I don't, so I can't really appraise the value of option #1, which is why I'm asking for the technical insight. I'm familiar with the crapshoot that is #2. I have the money either way.
serio, but why not skip all those and just do a full rebuild? snag the manual, save a ton on labor, and learn more than you want to know about your car!
There's a chip in the key-hole that connects it to the harmonic balancer. It's small now and the key is fairly tight, but mechanics I've talked to and forum members say it'll probably wear out eventually. As for when, who knows: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/help-crank-problem-stuck-motel-6-middle-nowhere-right-now-3021865/.
Engine runs perfectly now, but the guy who worked on it isn't confident at all that it'll run perfect for that long. And I don't think it's because he's trying to get money out of me, since he knows 100% that he'll never work on my car again, since I live nowhere near him.
Is replacing the crankshaft on these things REALLY that difficult?
Seems to me all you'd have to do is drop the oil pan, disconnect the harmonic balancer from the crankshaft, unbolt the bearings where the rods attach to the crank, and drop the crank out....or is it alot more complicated than that?
XP
XP
XP
XP
Also, you'll have to remove the engine from the car.
If you don't mind upgrading to a more powerful engine, you can find a D16Z6 for $750 on this site: http://www.nippon-motors.com/honda.htm
You would also need a P28 ECU, which usually run somewhere around $100 (cheaper if you can find one at a local junkyard)
There's a chip in the key-hole that connects it to the harmonic balancer. It's small now and the key is fairly tight, but mechanics I've talked to and forum members say it'll probably wear out eventually. As for when, who knows: https://honda-tech.com/forums/showthread.php?t=3021865.
The Grumpiest
XP
XP
Not necessarily true if he isn't doing any of the work himself.
XP
XP
you could also check Kelly Blue Book to get a value (private party) and then get a quote from a local installer. my personal rule of thumb: if the engine will cost more than 75% of the total value of the car, look for a new car.
yckan47
07-27-2014 05:46 PM
turks5
10-01-2009 02:01 PM
cilvia
01-22-2006 03:15 AM
