TPS calibration problem
Old 02-10-2012, 05:17 AM
NEEDBOUTTREE5O's Avatar
Default TPS calibration problem
EG Coupe, JDM B16. I just installed a Skunk2 68mm TB and I am trying to get the calibration right for the TPS. OK closed throttle 0.5V, WOT 4.5V. I set the WOT at 4.5 on the dot, let it sit for a few minutes and made sure it stayed there. Now this is where my problem starts. The lowest I can get the voltage for closed throttle to read is .776. Should I compensate for that on the WOT voltage? Or is my TPS sensor bad?
Old 02-10-2012, 12:18 PM
Default Re: More TPS problems.
Nothing at all?
Old 02-10-2012, 01:08 PM
phranky's Avatar
I'm having the same problem with mine. I'm assuming this can be fixed or calibrated with a tune? where in philly are you man? im local too.
Old 02-10-2012, 01:29 PM
Former User's Avatar
You are doing the calibration backwards. First set the closed throttle voltage to 0.5V. Then when you check the WOT voltage, it should be approximately 4.5V.
Old 02-10-2012, 01:51 PM
phranky's Avatar
Default Re: TPS calibration problem
Holy Cow RonJ havent seen you in years man, I was Frankmoocivic on clubcivic, how are you? I did the exact same thing my tps will not read any lower at closed throttle.
Old 02-10-2012, 01:56 PM
NE Philly, around Frankford and Academy. It's still a funtioning daily, but it gets annoying when I have to pull over to adjust. I just don't know if anything else could be casuing it other than the TPS.
Old 02-10-2012, 02:42 PM
phranky's Avatar
Isnt there a shopping center right there? ok I know alot of guys around there, if you want I can take a look later. Im not shy lol.
UKintegra
06-08-2011 12:32 PM
skuded
Engine Management and Tuning
11
12-15-2010 02:07 PM
mouab18c1
18
06-03-2010 10:57 AM
h2bv8killa
08-16-2007 02:14 AM
Goldfingiz
07-22-2003 01:26 PM
Quick Reply: TPS calibration problem
