96 Civic PRNDL turns off when i turn head lights on
Re: 96 Civic PRNDL turns off when i turn head lights on
Told me that the cluster didnt light up because of needing a new fuse sure enough i replaced the fuse and it did light up but as soon as i put a new one in and turn my head lights on the prndl goes off. if i remove the fuse the prndl works fine
The Grumpiest
Is the dimmer working?
Also check this in case the previous owner screwed up the wiring.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/wierd-electrical-problem-radio-turns-off-when-headlights-turn-%2Agoing-nutts-2521430/
O.G. triple O.G.
Definitely, the previous owner screwed up the wiring. A car's electrical system is not something to do trial and error experiments. Hopefully, the guy didn't mess it up too bad.
i pulled the dimmer out of the small socket its in and saw nothing wrong with the wires but cant get to all the wires is there any way to pull that air vent out?
The Grumpiest
Man. There are three threads going on with this same issue. Hacked wiring from the previous owner and various interior lights not working. TBH you guys are going to have to start checking all the affected wiring. Not a fun job.
looxs
11
02-05-2007 04:06 PM
