compression test issues - important
yesterday i did a compression test on jdm b16a in cold test before start up.
those are the following results i got: cyl 1- 180psi
2-175psi
3- 0 psi
4- 0 psi
when i see this result, i knew this is not good compression at all. could be blown or etc etc..
so i called the shop in orlando where i bought from. they tell me that it was because of cold. and they tell me that i should let run it up and warm it up. that my compression will build up. to be honest i doubt it. i still should get compression even in cold? is there any difference? should i start it up? please give feedback or anything. appriecate it
2-175psi
3- 0 psi
4- 0 psi
Re: compression test issues - important
you also have to have the throttle wide open, but even then it still shouldn't be 0. though compression tests should be done on an engine at operating temp.
sorry didnt see the part wet and dry.. umm i only did compression test. i believe it is dry. since i just bought it 2 weeks ago, there are still old oil left in there from previous owner.
just done redo test compression. with disabled fuel pump, wot and the result are still the same as above..
should i try start it up and see? with operating temp
well. i bought this engine from jdm shop in orlando two weeks ago, they tell me that the motor is in about 45k miles. so i replaced timing belt, water pump, spark plugs, spark wires, clutch kits and check underneath valve cover, i see light cooper/gold on internal parts from oil. everything seem good, i dropped in the engine bay, before i start up, i did compression test. and there goes the result.
i told them i need to replace other with known good compression on one of their engines. they go like, no no you need to start it up and let it run for a few day and the compression will build up. wtf it doesnt build up in a few days. it will have compression right there, right now as it should be.
I think the engine is toast. However, is the mechanical timing dead on? What do the numbers look like if you add a tablespoon of oil to each cylinder prior to the compression test?
yes i still have warranty until feb 25.
i added a teaspoon of oil to each cyl. number 4 improved but still underrated at 50psi, number 3 still has 0 psi. the rest still the same psi as before.
mechincal timing on? u mean tdc? yes the timings right..
yes, im going to call them back, but the problem is im deaf and they might think they can take advantage of me. i will let u know how it goes.. they better replace it.. should i replace the whole swap or just the engine self? i have no idea if the trans is good.
well i called back and they insist me to have it running first. they kept saying that the motor was sitting for too long time and probably loses it compression. so im gonna ahead run it up. if its still low compression after operating temp. then they want me to call back...
if they refuse to replace with their other known good compression i will take them to court for sure
