EG won't run
Re: EG won't run (civicmandx94)
It just wouldn't run after my wife filled it with fuel.
Turns over fine. I thought it was the coil so it was replaced. Still no go.
According to my workshop manual the Main Relay is at fault. Tested according to manual, no good. Replaced twice w/new. also bench test bad.
Checked associated wiring, all good including fuel pump, which does nothing when key is on.
Will recheck spark in the mornin'
Thanks, Stevan
Thanks, Stevan
Re: EG won't run (Rogue Si)
Check the ECU to make sure its plugged.....also, make sure ur wife didnt pump disel into the car.....my friends dumba^* did that once on his GSR...
this might sound pretty dumb but you should check an see if your wife didn't put the wrong type of fuel in like maybe diesel
[Modified by TooSlowTogoEF, 5:15 AM 4/1/2003]
Re: EG won't run (BCRUZ)
Well I have found a wire to the Main relay that has no power and should when starting and in run position.
It is a yellow/black wire from the fuse 24 position.
I have no 24 position that I can find.
I have chesked/doublechecked fuses
My fusebox map seems to be generic, and not 92 specific.
:Help!:
:Help!:
juanchoenuncrx
08-29-2007 07:59 AM
