what parts are needed for itr sway bars?
ive searched and come up with different parts here and there for what is needed for ITR rear sway bars on my 5gen civic ex coupe.. i know i need the 22mm rear bar, and integra lca for the mounting locations.. please give me a list of parts that i need to buy from acura or somewhere online.. thanks
and what sway bar should i go w/ up front??? and list of parts for them at as well.. i need to work on my suspension badly for handling and track purposes.. thanks everyone that responds
Location: Toronto, Canada currently residing in ATL, GA, USA
Re: what parts are needed for itr sway bars? (Hybrid95CivicEX)
If you have a 5g Civic you don't need Integra LCA's I believe.
You need the bar, endlinks, bushings (Unless you go with some ploy ones) and it would be wise to get a sub frame reinforcement kit, beaks or BSQ. That should be it.
I'm not sure which application you need, but I know you need end-links and anit-sway bar D brackets w/ bushings. ITR parts are probably what you need.
Re: what parts are needed for itr sway bars? (joe_bocc)
You will need:
22mm ITR Sway Bar
Brackets and Bushings
Endlinks
Chassis Reinforcement Kit
Integra Rear LCAs
Necessary Bolts and Nuts
Edit: For the front:
Si EG 21mm front sway or GSR 24mm front sway. Depends on what type of drive you are. i suggest the gsr front for less oversteer.
[Modified by EGTeK, 2:04 PM 3/31/2003]
22mm ITR Sway Bar
Endlinks
Integra Rear LCAs
Re: what parts are needed for itr sway bars? (EGTeK)
You will need:
22mm ITR Sway Bar
Endlinks
Integra Rear LCAs
22mm ITR Sway Bar
Endlinks
Integra Rear LCAs
as for the front, i already a factory sway bar on my civic ex coupe.. what else will i need to mount the gsr front sway bar in the car??? will it just bolt up using the factory endlinks, brackets, etc?? or will i need to get new parts.. thanks for all the help agian..
Re: what parts are needed for itr sway bars? (navin)
Keep the EX front sway... you will have less understeer + its just more work!!
1 Post
SI/EX 5g is 22mm - GSR is 24mm
Some people say the 2mm is not a difference, but I have the GSR + ITR rear and I did it because I thought it would be too "loose" with a 22mm front.
I just dont think its worth the extra time + $$...
if i was to go ahead and get the gsr front, what parts are needed to install it?? and can you post pics of your suspension setup or let me know how it runs.. this is what ive been thinking..
ITR rear sway bar w/ beaks kit
GSR front sway bar
Tokico Illimina shocks
Skunk2 Coilovers
Rear lower tie bar
front and rear strut bars
and a chamber kit once i get new tires this summer..
yay or nay??
1 Post
I am thinking you need GSR endlinks...
my setup is basically the same, upgrading later to either Custom rate GC's + Koni yellows or Tein RA's..
[edit] - tyres make your suspension, I reccomend Falken Azenis
[Modified by navin, 2:59 AM 4/1/2003]
95 civic turbo_gsr
Suspension & Brakes
05-02-2008 06:40 PM
lazyguy
01-06-2003 02:46 PM
B18Redline
07-09-2002 12:20 PM
