Caliper bracket problem.....need help
Just the other day I was changing the brake pads on my car and I ran into a little problem that I hope someone can help me with. The bolt that has a boot on the caliper bracket is frozen and I was wondering if there is anyway to brake it loose instead of having to replace the whole bracket. I went to the honda dealer and they said I would have to buy the whole caliper assembly if i want to get just the bracket.
Re: Caliper bracket problem.....need help (gohandbz8)
this happend to me way back in the day on my prelude. if i remember correctly we just used some wd-40 on it for some lube. then procedded to give it a little lovin with a rubber mallet.
Re: Caliper bracket problem.....need help (shepworldwide)
Heat the part where the bolt is threaded in with a propane torch. That sould solve your problem.
best of luck.
best of luck.
camarodude87
Suspension & Brakes
03-25-2013 05:23 PM
aasaa666
07-14-2009 05:16 PM
117
Welding / Fabrication
16
12-05-2007 12:04 PM
