Temperature gauge on si cluster.....
My engine temp gauge is shooting up to hot even though my engine is completely cold....Is there a senor on the engine some where i can look at to see if it is loose or is my Si gauge acting up? This is happening to my 96 EK hatch with a 99/00 SI gauge cluster.....
Re: Temperature gauge on si cluster..... (CM-R)
right under the distributor.....play with the plug....probabally got a lil oil on your contacts....if it is oily, fix the leak...
edit: also....plug in your original cluster...just to see if it acts up as well...eliminate the cluster as being the problem...
[Modified by 4g4me, 1:26 PM 3/31/2003]
Check the ECT switch right next to the lower radiator hose. When my temp guage didn't work that was the culprit. It wasn't erratic though; it just did not work at all.
HTH.
HTH.
This just happened when i got my car towed and had put in new axles after i broke the other ones.....
What color are the plugs for both the plugs you guys are talking about? Oh yea i have a 96 GSR motor in my EK
[Modified by CM-R, 2:35 PM 3/31/2003]
FloresEM1
08-12-2011 01:52 PM
o0ohaviko0o
04-01-2008 07:04 AM
