eg/ek front lower control arms?
are the 92-95 front lower control arms the same as the 96-00 arms? reason i'm asking is becasue awhile ago i swapped the front lower arms from a 93 si hatch onto my 99cx hatch in an effort to use its swaybars, the arms fit no problem but the front swaybar sat way too low. i want to know if i can just bolt in a front sway bar from the 96-00 civics using the 92-95 lower arms?
[Modified by sohc_boy, 7:57 AM 3/31/2003]
Re: eg/ek front lower control arms? (sohc_boy)
they should both be the two peice lca's. check here: www.hondaautomotiveparts.com
Re: eg/ek front lower control arms? (mugen76)
i was there already and the 2 diagrams they show of the ek and eg seem to show the control arms being the same although they carry diff part numbers on their site i'm not sure they are different. when i swapped my lower arms from my 99 cx to the older si's i compared them and they seemed to be the same except that the older arms had the hole sfor ther front swaybar where as mine didn't.
4drgsr96
10-24-2006 07:20 AM
