ecu is throwing code 9, No 1 Cylinder Position ?
Re: ecu is throwing code 9, No 1 Cylinder Position ? (lowboost civ)
try resetting the timing and then check, did you do any engine work latley where you may have changed the engine postion like cams/timing belt/crank pulley
any of these you may have accidentaly turned the engine moving it from tdc.
90civic-ZC
11-21-2011 06:45 PM
