Proportioning valve, EG rear disc conversion help please.
A little help please…
We’re putting GSR suspension on a 93 EG, and need to replace the proportioning valve…
Or will an ITR propo valve even work?
The ITR proportioning valve has only four inlets whereas the Civic has 6.
Following the lines on the ITR valve, all lines lead to the ABS system.
The civic are as follows.
Which lines go where on the ITR valve?
(Blue circles are rears)
ITR valve: this is the bottom, notice the plates covering the inlet... I wonder if these come out...
Thanks!
Thanks!
Re: Proportioning valve, EG rear disc conversion help please. (oryanh)
i am about to do my rear disk conversion as well and i just picked up the 40/40 civic prop valve because the integra one looked like it would not work because you would need to bend the hard lines and like you said it only had four openings.
I think it has something to do with the abs on integras.
you might just want to locate a prop valve from a civic ex or si that had 4 wheel disk
good luck
good luck
R won't work, thats not the valve you need since that one is from an ABS system. look for one that has the 2 in 4 out and is stamped 40/40
midnightdarknes5
05-20-2004 11:59 PM
