depinning at ecu?
depinning at ecu?
I'm trying to pop a few pins at the ecu, but after an hour i give up. I cant get one of them out... IS there a trick to this?
I've tried doing it mostly from the front side, where the holes are, and using a pin/needle to play around and try to get the pin loose.
I can't get paper clips in through the front , they are too big
Re: depinning at ecu? (sick hatchem)
use an eyeglass screwdriver. you need a flat end. each wire ha a prong on the end. when going into the plug from the back, the prong is pushed down. once it passes a certain point the prong expands. all that you have to do is press on that prong with a flat edge from the front while pulling the wire from the back.
with all that said... don't do it.
i am assuming that you are plugging another wire into the existing hole.
cut the wires instead. that way if it all goes to ****, you can still tell where the wires were originally.
****, it only took me 5 min to figure it out. 2 hrs later i had a repinned ECU up and running. yes i did repin every wire, about 56 or so at the ECU.
Re: depinning at ecu? (RedlinedVTEC)
IT was actually for pre OBD plugs, but i'm all set now.
ONce i got the hang of it, i pulled the 7 pins i needed in two minutes, it just took me 2 hours to get there, haha
Thanks guys.
Thanks guys.
EE_Chris
12-02-2003 09:40 AM
Loaded Butane
02-23-2002 05:08 PM
