burning oil
burning oil
ok 1st off my car does not have a cat and is running a little rich due to o2 issue.
my civic always burned a little oil but not to bad. i just did a head swap and i am having a little o2 problem due to a 1 wire o2 when i need a 4 wire one its going thru the same amount of oil but at idel with window down it stinks like hell and around 5000 rpm's it shoots a good amount of smoke. my question is is there a good oil treatment out there that could help with the oil burning. i do know i need to fix the o2 but i dont know how to. i am all so looking at getting a cat in the next few months.
*edit* i use oem honda oil filter and mobile 1 5w 30
Re: burning oil (cxjon)
You say u swapped your head...did you replace the head gasket. Thats one gasket you don't want to try to reuse. Or is the gasket on correctly and your head bolts properly torqued.
Re: (civic_rice)
bump i wanna know too
i have the same exact problem smoke's really bad after the head swap had the engine torn apart twice ...i think my ring's gave out since my block had 175,000 miles and the head had only few thousand
what color is the smoke comming out the tail pipe? if you are burning oil check things out like pcv system, rings, valve stem seals, ect... also im sure you have raw fuel comming out the tail pipe since you dont have the o2 hooked up. and that might be what smoke your seeing. do not buy a cat until you fix your probelms because oil and raw fuel will destroy the cat and that would waste your money.
i got a new honda oem head gasket when i did the head swap, my rings looked good no scoring on the cyinders. it look white / light / med grey at time. i am color blind :D
Re: (cxjon)
i am running my one wire o2 but am getting a code 41. i have p06 and p05 ecu's. with the p06 i get a code 41, with the p05 the car runs but bugs alot no codes. what should i do
get a 4wire o2 and wire it up to the p06 ecu
or get a vafc and bump up the fuel for the p05
or get the p05 chipped
Re: (cxjon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxjon »</TD></TR><TR><TD CLASS="quote">i got a new honda oem head gasket when i did the head swap, my rings looked good no scoring on the cyinders. it look white / light / med grey at time. i am color blind :D</TD></TR></TABLE>white smoke is coolant or condensation and bluish is oil. doesn't matter what o2 u got that won't prevent oil burning. if your head gasket and rings are good it may be the valve seats. they may not be seating properly and allowing oil into the combustion chamber.
Bad, worn valve seals will cause the smoke. I would begin to look for a new motor. You shoudl be able to run yours for a while longer until you start to consume a good deal of oil.
Re: (Jmunk)
i could pop the head off and redo the valve seals if thats the problem? where is the pcv valve. it only smokes bad at around 5 grand and you dont see it till then as well
Cameronphelan
Honda Civic (2001 - 2005)
05-29-2015 10:23 AM
