HELP!!! NEED A MODIFIED HARNESS TO PUT A B SERIES MOTOR IN A 96-98 civic
Re: HELP!!! NEED A MODIFIED HARNESS TO PUT A B SERIES MOTOR IN A 96-98 civic (derekolerude)
what are you talking about? The actual engine harness? or the ECU harness? If you have an OBD-I motor and ecu, u'll need a conversion harness. I suggest Kenji for that one. If you are talking about the engine harness, its just a matter of swappin and switching over plughs and such from the harness on the motor to the existing harness. Nothing difficult. Most swap right over.
use your stock harness and add/modify the necessary wires.......
already got rid of your stock harness? buy a 96-98 ex harness
I think boomslang had them on sale for 75 and Kenji makes a real nice conversion harness also. His are all factory color code.
Why don't you get the whole wiring harness with the motor and then you won't have to worry about anything. You could even go obdII if you wanted to. All you have to add to your dx harness would have been knock sensor, vtec solenoid and actuator lines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by derekolerude »</TD></TR><TR><TD CLASS="quote">...and i am getting a obd2a to obd1 conversion harness soon, if u know of one for sale let me know</TD></TR></TABLE>
Kenji
Kenji
No www, but you can contact him via email at kenji211@tampabay.rr.com
He's a good guy and has a great rep on HT.
I'm sure he could get/make anything you may need as far as wiring and ECUs.
