93civic headlight housing removal??
did a search but nothigng came up...
id like to know which screws have to be removed in order to take out the whole assembly.
thanks
andy
thanks
andy
Re: 93civic headlight housing removal?? (andyboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andyboy »</TD></TR><TR><TD CLASS="quote">did a search but nothigng came up...
thanks
andy</TD></TR></TABLE>
Actually I think its bolts. Unless you are removing the corner lenses then its a screw. Its not that hard grab your tools and monkey around with it you will get it out. Just remember where everything goes so you can put it back together.
thanks
you need to take out the corners, the bumper, then a L bracket under each eadlights......
the corners have 1 screw each
the bumper have 3 bolts on the bottom, 5 on top, 1 screw under each rim wells
the L bracket should have 2 bolts
then the headlight houseing should have 3(?) bolts
might be more, but i cant remember right now
WIb16crxWI
05-10-2006 12:07 PM
