rear LCA bolt broken off... Please HELP Me..!!!!!
Re: rear LCA bolt broken off... Please HELP Me..!!!!! (B16B)
when mine was stripped, i use a die grinder and grinded the head of the bolt off. then i went went ahead a drilled a little hole enough to stick the craftsmans screw out and it just came right out. itll take some time to do.
Re: rear LCA bolt broken off... Please HELP Me..!!!!! (=GAMEOVA=)
the problem is that this is seized. I had been soaking it with penetrating oil every day for a week in hopes that it would be freed up by the time i wanted to take them off.
I cannot drill through it because the material is too hard. If i had a torch, id cut that sheit out
Re: (OOsi)
i dont care about the lca's because i have JDM ones to replace them. I am worried about the subframe. It is also not as easy to "just turn the pointy screw" because it is seized. This is what caused the problem in the first place.
Peter K
04-06-2002 01:44 PM
