assorted rear disk swap questions...
So I just pulled a rear disk swap off a 96 gsr to put on my 96 civic EX.
1. I cut the brake lines, i know mine probably wont work, where should i get the proper brake lines?
2. Does integra rear shocks and struts have to be used? if not, is there any significant advantage to using them?
3. Can i use an integra brake MC?
4. where is the prop valve on the integra and what does it look like? ive heard i need it.
5. and on a side note, can front integra calipers be used instead of mine? should i get any front suspension hardware off the GSR?
appreciate the help fellas
1-get brake lines from local junkyard, or acura. 2-the teg struts dont have to be used. 3-idk. 4- on the fire wall...odd shaped aluminum piece that has brake lines feeding into it. 5-yes, i have them myself
B96v6
02-28-2006 08:01 AM
jefe
30
12-11-2004 12:41 PM
