PLEASE hooking up vtec .. p08 to d15b
hey guys i just swapped a jdm d15b into my 95 civic sedan
put in ecu - p08
just wondering how i would hook up the vtec
can any1 give me step by step and pics would be helpful thanks!
please stay on topic
put in ecu - p08
err,, the wiring should be the same
its just an ecu,
is there anything ivolving opening up the ecu and modifying it for the p28? if not it shold be the same.. ecu's just plug in..
its just an ecu,
Re: (Slammd Sol)
im guessing
VTEC Solenoid Yellow/Green A4
VTEC Oil Pressure Sensor Blue (passenger side harness) D6
VTEC Ground Black chassis ground
Re: (labatia)
vtec solenoid A4 plug
vtec oil pressure switch (sensor) one wire to the ground second to D6 doesn't matter which one
You are going to have to get some ECU pins and learn how to put them in though.
Re: (labatia)
The p08 is the JDM version of the p28 so it does have vtec I am sure you know that but like you mentioned some people speak but dont know ****.
Vtec Selinoid is A4 the same as the p28 I have a p08 on my swap as well you should really get a haynes book it helps alot.
92accordh22a
12-16-2006 07:21 AM
h kid
06-18-2005 11:42 AM
