What Engine Comes In A 92 Civic Dx?
A friend needs some help locating an engine for his 92 Civic DX, just curious what year/model engines are compatible to bolt in with no wiring differences.. I have a swapped 88 CRX Si, just dont know much about 92 Civics Let me know, also lemme know if you have one for sale
Re: (Doh!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doh! »</TD></TR><TR><TD CLASS="quote">So then my next question is how compatible is a D16?</TD></TR></TABLE>
you mean like if parts are interchangeable?
then yes.
then yes.
Re: (Doh!)
For no wiring differences you can put in an OBD1 B18B or B20. Some others like OBD2 B18B and B20, and D16Y7 and F series I suppose can go in without a VTEC ecu and wires run, but they must have conversion harnesses or mounts for the F. A D16Z6 can be dropped in by getting a P28, P30, or P08 ecu and running the 2 wires from the VTEC solenoid and other thing (? it has a black and yellow wire, that's all I know) to the ecu. B series is pretty much the same, just use the B mounts and run the wires. H series and F need mounts and the H22 needs a VTEC ECU. That covers a lot, but still you should search.
Basically my friend blew their motor, and I need to find one that is a direct drop-in.. If I'm correct either the D15B7 (OBD1) or an OBD1 D16 will both bolt in with no wiring or other changes.. Any confirmation is appreciated, thanks for the help.
Edit: My friend has a D15 out of a 92 Civic CX, which is just 8 valve instead of 16 correct? If I'm not mistaken it will bolt up?
Modified by Doh! at 11:04 PM 5/13/2004
Re: What Engine Comes In A 92 Civic Dx? (DanW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DanW »</TD></TR><TR><TD CLASS="quote">D15B7</TD></TR></TABLE>
Re: (DanW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DanW »</TD></TR><TR><TD CLASS="quote">So did the LX.</TD></TR></TABLE>
You're right...so the 92-95 LX and DX came with the d15b7.
Re: (Doh!)
any SOHC from a 1992-1995 will bolt right in and run fine if you get the ecu with them and wire up the vtec if they have it. they will run off of the ecu in the car just not quite right (wrong fuel and ign maps, no vtec)
Re: (Doh!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doh! »</TD></TR><TR><TD CLASS="quote">His D15B7 died due to oil starvation, looking for whatever I can locally to replace it with.. Power isnt really an issue</TD></TR></TABLE>
But still, you already have the ECU for the D15B7. Don't you have any local import yards?
