ANYONES CAR EVER JERKED SO HARD YOU THOUGHT SOMEONE HIT YOU??
Well when my clutch warped,it got really hard to get into gear.i always had to wait till the revs dropped till it would actuall;y go into gear but what made me decide not too prolong this problem anymore was when my car started violently jerking as if someone rear ended me or something.Could this still be the cluctch? Has this ever happend to anyone and can you give me insight on what this could be?
Re: ANYONES CAR EVER JERKED SO HARD YOU THOUGHT SOMEONE HIT YOU?? (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Yeah when I was learning stick...man that was fun.</TD></TR></TABLE>no man its REALLY bad ,worst than an unexperienced driver learning stick,its like in got rear ended or something.I hope it stops when the new clutch is in
Re: ANYONES CAR EVER JERKED SO HARD YOU THOUGHT SOMEONE HIT YOU?? (rocco)
did you break the clutch in when you got it. That hapened to me when i decided that the break in period would only be around the block, then the pressure plate and flywheel got hotspots everywhere and had to be resurfaced. But it was really jerky because it got warped..
Re: ANYONES CAR EVER JERKED SO HARD YOU THOUGHT SOMEONE HIT YOU?? (AllMtrADVAN)
I havent ran the new clutch yet,what do hotspost look like cause on my pressure plate i saw these little blemishes on the metal
It is probably not your clutch. The problem is probably your flywheel. Maybe your flywheel is warped and is not spinning true. When you take your clutch out make sure you either get a new flywheel or get your existing one resurfaced. I would recomend getting it resurfaced because it is much cheaper, especially for me, 20 bucks.
Jabinya
05-12-2007 04:26 PM
