Rear quarter panel extraction ?
Heya !
I'd like to know what would be the fastest, simplest and cleanest way to remove the part squared in red in the picture. Blow torch ? I might not be able to use electricity where the car is, since it's in a car graveyard.
thanks a lot for inputs
the whole wuarter panel or just that one part?
if you just want that park out to put like metal over it due to rust then plasma cut the metal and weld on sheetmetal. but then again i don't know what you mean by your question.. you might want to edit your question.
Re: (H22BuiltEGhatch)
I am currently having some difficulties explaining my question in english...
I want to remove the part in the red square (approximatly) from a "A" car to use it on a "B" car later on.
Is that better ?
Is that better ?
Re: (STN_Pat)
Die grinder will be the easiest if you are asking what I think you are. You're trying to cut out that square to use later on? I know you said you may not have electicity, but a torch will warp the metal.
Re: (x743x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x743x »</TD></TR><TR><TD CLASS="quote">Go to a tool rental place and rent an air compressor and electric hacksaw, or a cordless reciprocating saw (sawzall). </TD></TR></TABLE>
Unless you know what your doing, you can destroy the metal. Plasma cutter is optimal, but at a junkyard electricity isnt available. A dremel will do the job, just be careful and keep the blade moving.
Re: (TODAeg6)
my friend did it on his 92 integra. He drilled out all the spot welds, then pulled the skin off. He replaced it with a new one and welded it back into place. Lots of time and hard work but it can be done.
Re: (TODAeg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TODAeg6 »</TD></TR><TR><TD CLASS="quote">
Unless you know what your doing, you can destroy the metal. Plasma cutter is optimal, but at a junkyard electricity isnt available. A dremel will do the job, just be careful and keep the blade moving.</TD></TR></TABLE>
You would suggest a plasma cutter over a sawzall? Ha, sawzall is the easiest tool to use. You really cant mess up at all.
Re: (TODAeg6)
Plasma cutter requires normal electricity only ?
I doubt the junkyard will be able to give me any electricity...
I only want to remove the part and go home with it. I'll do whatever detailing on it when i'll have it in my hand. I can resize it and remove the **** i did with a cutter, but the main objective is to get the quarter out of the junkyard as simply as possible.
Re: (STN_Pat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STN_Pat »</TD></TR><TR><TD CLASS="quote">sawzall it will be then </TD></TR></TABLE>
yea, sawzall will take you like 2 minutes to do the whole thing. If you 've ever used a jigsaw or a dremel before, you can easily use the sawzall. Just gotta find a cordless one. Maybe you know a contractor or someone in construction that will let you borrow one if the tool rentals places dont have it.
Re: (x743x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x743x »</TD></TR><TR><TD CLASS="quote">yea, sawzall will take you like 2 minutes to do the whole thing. If you 've ever used a jigsaw or a dremel before, you can easily use the sawzall. Just gotta find a cordless one. Maybe you know a contractor or someone in construction that will let you borrow one if the tool rentals places dont have it.</TD></TR></TABLE>
i'll def. be able to find one. I just tought it would not be strong enough, but i've never use this particular kind of saw.
thanks a lot for infos. i'll post pic when i have it
-Pat
-Pat
Sivik
03-18-2003 08:19 AM
