Swap Help - L@@K
Swap Help - L@@K
I recently swapped a JDM B18C (Type eeeR) into my 97 Civic DX. I notice that inside the car (when driving @ high speeds) it feels like a damn steam room (ITS H0T)! The car doesnt overheat (stock dX cooling equipment). I also have noticed that my engine bay is HELLA HOT (hotter than normal) when car is warmed up. I have JASMA header w/ carsound cat and custom piping to magnaflow oval exhaust ... so my Q is :
1) Why does it feel so hot inside the c0ckpit? Does it have to do w/ my piping?
2) Would switching to a bigger cooling system cool down my car as a whole (IE Inside bay and inside) and what are some CHEAP alternatives?
Thanks .....
Thanks .....
Re: Swap Help - L@@K (SiRacer365)
you could always get a higher cfm fan from advance auto parts for like 50 bux and it will keep your engine bay a lot cooler that the stock one
if you have carpet and stuff like that removed you will feel more heat, that and you now have a larger engine sitting closer to the firewall so it gets hotter faster
When you're driving & notice the heat, put your hand by your e-brake and see if you feel heat from there. When I supercharged my car, I noticed heat would just pour in from the e-brake. There wasn't anything I could really do about it, except get rid of the SC, which I did. Now my car is cool as a cucumber! (slow, though)
I'm also curious if the heatshields are still there?
levels1069
45
07-29-2004 01:28 PM
Spade
23
07-30-2002 04:27 PM
