d16y5 - OBDII to OBDI
I know this has probably been covered before, but I can't seem to find the info. Is there anything special about converting the y5 from II to I? It seems to have a more elaborate o2 metering system, so I'm not sure if that'll effect it. So has anyone done this, and if so is it any different than doing a y8?
Re: d16y5 - OBDII to OBDI (jolt-tsp)
bump cuz id like to know too
my assumption would be: with the the odb1 conversion, the obd1 ecu needs a narrowband sensor input. so your hx wideband sensors will be moot. rewire your harness(i dont know if it needs to) so a narrowband sensor works with the new ecu.
Re: d16y5 - OBDII to OBDI (tilt)
Hmm. if thats the worst of it, it shouldn't be too bad. Anyone with experiance in the are have any input??
justinCO
08-02-2009 07:26 AM
jamesracer
03-14-2007 10:15 AM
