Throwing CEL 5, and 14.. searched.
00 LS obd1 wiring harness p75 LS 95-94 ecu in a EG6.
Getting cel code 5, map mechanical?
I've tried changing the map sensor with another one and doubble checking the wiring. btw: Map is on the throttle body not through a vacume hose. Searched topics, but coulden't find any that had a diagram of the sensor, but mainly problems.
Does anyone know have a diagram of where the 5v wire/ground wire/map sensor wire/ go on the map sensor clip? I think I am getting problems there might have them switched around since I Had to rewire my whole car after some ******* stole my car and cut my ecu clips off. Anyways, does anyone know the correct wiring order of the clip with its plugged into the map sensor looking at it from left to right, standing passenger side? The green/yellow/red wire?
I am also getting cel 14, Idle air control valve.
I've tried checking the wiring to the ecu, but it's pinned correctly. I've tried checking the resistance in the IACV I get 12, spec was 8-15, but when I take the IACV plug off the car will idle fine at 800. Once I stick the clip back on and start the car it bogges from 1500-2500 up and down. I've read up on the IACV and i've already tried taking it off and cleaning it. Anyone know why it's throwing 14 and 5?
Re: Throwing CEL 5, and 14.. searched. (Ski11z)
https://honda-tech.com/zerothread?id=682412
its the second topic titled
[FAQ] ECU codes for everyone.
Re: Throwing CEL 5, and 14.. searched. (b20_EK)
Maybe you should read the whole post instead of the last sentence.
FYI that page shows you how to jump the CEL harness to grab codes. I already know how to get CEL codes and what they are.
I am asking for a diagram of the clip connected, what each clip is map (i.e 5v/map sensor/map ground) and what color it is, and where it goes on the clip.
I am also asking for help with the IACV, which is throwing CEL 14, but it's in resistance spec, and it's been cleaned.
baulum
04-09-2008 11:32 PM
jus_spooln_wicha
06-13-2007 12:04 PM
