Hissing sound from throttle body area
Old 05-15-2013, 08:39 PM
delsolboi's Avatar
Default Hissing sound from throttle body area
93 del sol si 217,000 miles. The car erratic idle and goes between 700-1100 rpms. Doesn't stay constant at a certain rpms. I can't seem to pin point the hissing sound that's coming from the throttle body area. Usually when the car is cold it doesn't seem wanna accelerate and seems to get stuck and then all of a sudden lurches forward. Anybody had a similar issue? I don't know what to do. Thanks
Old 05-15-2013, 08:40 PM
ReaperMan's Avatar
Default Re: Hissing sound from throttle body area
vacuum leak
Old 05-15-2013, 08:42 PM
andyz's Avatar
Spray that bad boy throttle hiss with carb cleaner, you'll find it that way. When you get to where you can stall the engine with carb cleaner I think you got it.
Old 05-15-2013, 08:43 PM
delsolboi's Avatar
How can I find it? I did spray around the throttle body but didn't seem to change anything?
Old 05-15-2013, 08:46 PM
andyz's Avatar
You should be able to hunt around and find it, try the gasketed bolted areas, right next to the engine.
Or maybe lite a big fat cigar and see if you can see where the smoke migrates toward.
Old 05-15-2013, 08:52 PM
andyz's Avatar
Or the hoses that come off and go to the brake booster. Anything after the throttle plate itself. Or I guess take the hoses off and stick your finger in the hole where they came from to see if the hose is leaking and not the throttle body.
rockcity
04-22-2008 01:46 AM
Rex-Si
41
04-04-2007 01:30 PM
bootlegtrader
02-05-2006 09:04 AM
poop32145432
03-28-2004 10:01 PM
ultra efro
02-22-2004 05:53 AM
Quick Reply: Hissing sound from throttle body area
