OBD-2 question.
OBD-2 question.
Im curious if anyone has monitored data coming from the OBD-2 system and sensors.
I have technician's equipment and I am not getting nearly as much data as I was from a 98 Ford OBD-2.
Im reading no trouble codes, revolutions,engine temp and vehicle speed.
Not sure if this is because the data in this system is not as detailed as what Ive been able to read from an equal year Ford.
Just curious.
Thanx ahead of time.
Just curious.
Re: OBD-2 question.
obd2 hondas do read live data...injector pulse, rpms, egr activity, tps %, map info, all kinds of stuff... something is wrong with your scanner or ecu
Re: OBD-2 question.
i use my snap on solus and i have never had such an issue with any honda.
weird situation, either the scan tool is bad or the ecu won't communicate... OP, are you getting ANY data readouts?
Re: OBD-2 question.
Very limited data. Im wondering if the obd system is shot, im only seeing 3 to 4 wires running into the OBD2 connector, witch seems a bit low to me considering its a 16 pin connection.Im also aware though that not all manufacturers make use of all the pins.
Other then that just typical dash lights, SRS,check engine light comes on for a small second then goes out before starting the engine, break and battery lights are the only others.
Re: OBD-2 question.
PID's are limited on Honda vehicles compared to the domestic Ford you mentioned. But it seems you have not even established a connection with you Data link connector.
If you have a jumper harness with older ECU the DLC will become inactive, If you have the correct OBD2 ECU then I would check that the wiring is correct, and no fuses blown
Re: OBD-2 question.
It works or it doesn't
Not all the pin locations on the DLC will have wires going to them, Different for different makes and models, some more or less
you need to check the wiring diagrams found within the service manual to check that the wiring is consistent of those diagrams.
Re: OBD-2 question.
So you are getting a sane reading for RPM? That changes when you hit the gas? Then the scanner and the data connection is working, no doubt.
The supported PIDs (parameter identifiers) can vary between vehicle manufacturer and scanner manufacturer. *I'm not totally sure there is a specific set required in the OBD II standard. *AFAIK The OBD II standard is more about the ability of the on board computer itself to set the check engine light and continuously monitor the state of certain systems critical to emissions, not particularly to standardize the human interactive diagnosis part....
So, for example, I think actually your vehicle manufacturer could support absolutely zero live data PIDs, and your car would still pass emissions, and be OBD II compliant because the emissions monitors report an ALL OK status...
Re: OBD-2 question.
Punctuation
It's already determined that the DLC is not active and or communicating with his scanner.
OP you need to also check your scanner and see if it a model specific to Domestic vehicles only. Even when some scanners advertise they will function with any vehicle operating on OBD2, some tend to have trouble establishing a connection with certain makes/models.
I have a 2000 Si with 2000 USDM type R ecu and live data/monitors/cel status/etc. is all active.
Although the list of Pid's are pitifull due to Honda's primitive sub-standard OBD2 implementation.
Re: OBD-2 question.
What EXACTLY does limited mean?
It doesn't matter the pins aren't all connected. All different parameters are transmitted over a single wire in a serial format.
Re: OBD-2 question.
Although the list of Pid's are pitifull due to Honda's primitive sub-standard OBD2 implementation.[/QUOTE]
My scan tool is my 3 month old laptop.
It is coming down to Honda's crappy OBD2 PID implementation.
OBD2 protocol is SAE 9141-2. I get some data, but not nearly as much as I would like, This is not because of my software or hardware, just Honda's.
Its not crazy necessary to me to get all the data, I have no MIL's. It was more about getting a computated fuel economy data.
Thanx all that replied!
ek9800
11-09-2004 04:50 AM
